Seeed Grove PCB through hole mounting 90° female 4 pin connector (pack of 50)
Sold By Wyld Things
What is it? Standard Seeed grove 4 way female connector for 90° mounting through-hole to a PCB. These are 2mm spaced connectors (not the usual 0.1"-2.54mm header spacing). See https://www.seeedstudio…
Read More…Standard Seeed grove 4 way female connector for 90° mounting through-hole to a PCB. These are 2mm spaced connectors (not the usual 0.1"-2.54mm header spacing). See https://www.seeedstudio.com/Grove-Universal-4-pin-connector-90-10-PCs.html The unit price is for 5 packets of 10 connectors (see photo)
Stock purchased for a discontinued product.
Useful to add to a PCB to be able to connect Seeed Grove type expansion boards etc, or just to use as a board to board cable connection using the Seeed cables.
Enter your email address if you'd like to be notified when Grove Female Header - DIP-90°-4P-2.0mm-50 Pcs can be shipped to you:
Monday is the day for package preparation and shipping.
Rob | Nov. 14, 2023
