PCb for +/-15V and 48V supply, ideal for microphone pre-amplifier
Designed by Australian Technical Production Services in Australia
Linear power supply for mixing desk, microphone pre-amps or other projects This is a power supply designed to be as compact as possible, with a footprint of 109mm by 23mm and uses fixed regulators (7…
Read More…Linear power supply for mixing desk, microphone pre-amps or other projects
This is a power supply designed to be as compact as possible, with a footprint of 109mm by 23mm and uses fixed regulators (7815, 7915)
This power supply will deliver +/- 15V at 1 Amp, 48V at up to 1/4 an amp
It uses a voltage multiplier to generate the 48V supply so can use readily available power Transformers with either dual 15V windings or centre tapped 30V windings.
At the moment the kit consists of PCB and instructions only
Enter your email address if you'd like to be notified when small Audio voltage regulator board can be shipped to you:
Hornsby, New South Wales, Australia
Ships from Australia.
1 Review | 38 Orders
$5.95
