3-22 V Unidirectional Electronic Fuse (e-Fuse) with Latch-off Circuit Breaker functionality operating up to 5 A continuously.
Designed by PN Labs Inc. in Canada
The PN Labs FlexTrip is a highly capable unidirectional electronic fuse with ideal diode functionality, working from 3-22 V at currents of up to 5 A continuous. It can be used solely as an electronic…
Read More…The PN Labs FlexTrip is a highly capable unidirectional electronic fuse with ideal diode functionality, working from 3-22 V at currents of up to 5 A continuous. It can be used solely as an electronic fuse, to isolate multiple supplies in parallel, or to perform power multiplexing between multiple power sources using the Power Good (PG) and Reset (RST) signals.
Its features include:
Overcurrent Response Behavior: The short circuit threshold is defined solely by soldering the corresponding solder jumper.
If downstream loads attempt to exceed the set current limit, the device will actively regulate the input voltage in an attempt to not exceed the limit. If enough heat is dissipated in the device that its over-temperature feature activates, it will latch off.
If the overcurrent event is severe enough that it exceeds double the set current limit, the device will skip current limiting and immediately shut down, latching off.
The module can be used to perform power multiplexing/power path control by sending a signal to the reset pin to turn the module on or off.
I made this module because electronic fuses offer a more reliable and convenient solution than conventional fuses, but there are surprisingly few electronic fuse boards available on the market today, and if they do exist, they are not rated for low voltages like 3 V and are very expensive.
This module is sold a pack of 2, and comes with all required header pins and terminal blocks.
Enter your email address if you'd like to be notified when FlexTrip: Adjustable Current e-Fuse 3-22 V, 5.5 A can be shipped to you:
Ships next day if in-stock, through Canada Post/USPS or UPS. Shipments are delivered without duty paid (DDU) unless you contact us to arrange payment of duties beforehand, as the Tindie marketplace does not offer a way of estimating them before the order is placed.
| Quantity | Price |
| 1-4 | $20.99 |
| 5-9 | $21.49 |
| 10-24 | $20.99 |
| 25+ | $19.99 |
$23.99
$16.99
$23.99
$59.95
$23.99
$16.99
$36.00
$23.99
