120 Injection Molded DIY Tank Tread Links with Hinge Pins
Designed by Powerhouse Electronics in United States of America
Description: Super durable "super tough" injection molded tank tread. The links are held together using a standard 4d 1 1/2in nail (also included). The head of the nail snaps into the link which, i…
Read More…Super durable "super tough" injection molded tank tread. The links are held together using a standard 4d 1 1/2in nail (also included). The head of the nail snaps into the link which, in turn, holds the nail head securely. Note, the nails must be cut to length before use.
The TT-120 shipment includes 120 super tough tank tread links. Plus, 120 nails which provide the hinge between each link.
From where we stand, there simply does not appear as though there is any good tank tread on the market.
The link design is special because custom length tread belts are super easy to make. This is done by simply removing a pair of hing pins (nails) to adjust the belt length.
The TT-120 contains 120 links which will make two belts just over 24 inches in length.
3D printable hubs design files are provided. The hub design files (provided in SolidWorks, Fusion, and STL) are open source. This allows for customizing the hub design to suit special designs.
Enter your email address if you'd like to be notified when DIY Tank Tread can be shipped to you:
Troy, MI, United States of America
$28.00
$139.00
$300.00
