Drastically improve cooling on your Valve Steam Deck OLED with this kit
Designed by Low Budget in United States of AmericaNo shipping info available.
The CoolDeck v4 is now available for OLED and LCD versions Steam Deck. If you have a LCD Steam Deck, check its motherboard version. The [revised] v2 LCD Steam Deck motherboard is not compatible with …
Read More…The CoolDeck is a machined copper plate that replaces the original EMI shield on your LCD Steam Deck and acts as an additional heatsink to keep the APU cool. Operating temperatures are reduced by 10-15 degrees without any external fans. The CoolDeck can be combined with other cooling mods, such as vented back panel and fans for an even greater temperature reduction.
Features: - Solid 101 copper - 10-15 degree APU temperature reduction - Unobstructed access to internal storage and power / fan connectors - Replaces original EMI shield
What's included? - CoolDeck 101 copper plate 1.6mm thick - 3 M2 x 4mm stainless countersunk mounting screws - 1.3mm hex key - 4 thermal pads (LCD version only)
What's required? - #00 Phillips or Torx T6 driver and plastic pry tool for Steam Deck disassembly - Thermal paste
Installing this modification requires opening your Steam Deck. I am not responsible for any damage caused by incorrect installation. Thanks for looking!
Enter your email address if you'd like to be notified when CoolDeck Cooling Mod for Valve Steam Deck LCD OLED can be shipped to you:
Product: (4.75)
Documentation: (4.00)
Shipping: (4.75)
Communication: (4.75)
Euiyeol | Dec. 29, 2025
Hoang | July 22, 2023
Andrew | April 7, 2023
Kelly | April 1, 2023
33 Reviews | 1,417 Orders
