lot of 5 pieces Solum 1.54" epaper electronic shelf label, black/white/red, with custom firmware for use with OpenEPaperLink.
Sold By {Electronics by Nic}This product is no longer available for sale.
What is it? These electronic shelf labels were used in a store. They contain a nice 1.54 inch three color epaper display, white/black/red, with resolution 152x152 pixels. If you order quantity 1, you…
Read More…These electronic shelf labels were used in a store. They contain a nice 1.54 inch three color epaper display, white/black/red, with resolution 152x152 pixels. If you order quantity 1, you get 5 pieces, 2 = 10 pieces, etc.
These tags aren't new, they may show some light cosmetic damage. Programmed with the OpenEPaperLink firmware. For shipments within the EU, the tags include batteries (only when shipped within the EU). But as they are not new, I cannot estimate the life span of them. The tags take CR2450 batteries, they can be found online.
Supply is very limited. When they are sold out, I don't expect to be able to get more stock. As I only have a limited amount of these displays, and I want to make as many people as possible happy to get one or two, the unit price will go up if you order more than two at a time. My apologies for that.
The tags are ready to be used with the OpenEpaperLink system. If you're just starting with OpenEPaperLink, you'll need an Access Point too. You can buy a kit to make an Access Point here, or you can make one yourself.
Another possibility is to repurpose the bare epaper display. It is compatible with the SSD1619A driver chip. It takes some careful work to split the display from the pcb without braking the glass (it is glued with double sided tape). I also sell a driver board separately.
1-2 | $35.00 |
3+ | $40.00 |
Documentation: (4.00)
Phil | Nov. 18, 2023
$139.00
$94.95
$89.95
$36.00
