Intermatable SMD tape holders that come in different sizes so that you can individually swap them out for your needs!
Designed by Der-QuerDenker in Germany
Newer and better Version now available ->Here<- I designed a system of SMD tape holders that is perfectly adjustable for your and my needs when we are doing hand pick and place tasks. The small and c…
Read More…Newer and better Version now available ->Here<-
I designed a system of SMD tape holders that is perfectly adjustable for your and my needs when we are doing hand pick and place tasks. The small and compact tape holders have hooks that grab into the next holder and that way they form a nice and straight row of SMD holders. You just need a little bit of double sided sticky tape to attach them to your work place. After that you just feed in the SMD tape and fold over the plastic film from the tape into the smaller slot.
The tape holders are designed and printed right here in Germany by myself and they come in the color "Black". The standard length is 55mm. If you want for some reason another length or size, please contact me. They will get cheaper, if you buy more!
There are two different types for the same SMD tape size. The reason is that tapes come in two different kinds. One is made out of paper and is relatively thick. It is used most often for resistors, capacitors or some other small parts like that. The other kind of tape is made out of plastic and is much thinner than the paper kind. I have just seen the paper kind for 8mm tapes, but made options for the greater sizes too, just in case.
| Quantity | Price |
| 1-4 | $1.60 |
| 5-9 | $1.50 |
| 10-19 | $1.30 |
| 20+ | $1.10 |
$3.50
$28.00
$19.97
