PSP Analog Joystick Breakout: Compact 2D control for projects with proportional voltage output. Easily integrates with Arduino & RPI
What is it? Introducing the PSP Analog Joystick Breakout Board - a compact and versatile solution for adding a joystick control to your projects. Dual Axis Control: Detects both vertical (up/down) an…
Read More…Introducing the PSP Analog Joystick Breakout Board - a compact and versatile solution for adding a joystick control to your projects.
Dual Axis Control: Detects both vertical (up/down) and horizontal (left/right) movements, offering a comprehensive 2D control experience.
Voltage Output: Provides proportional analog voltage outputs corresponding to the joystick's position. This allows for precise measurement and interpretation of the joystick's movement.
Self-centering: Once you let go of the joystick, it will move back into the center position.
Compact Design: With its minimalistic footprint, it can be effortlessly integrated into space-constrained projects.
Easy Integration: Standard pin headers ensure compatibility with most microcontrollers and development boards, such as Arduino, Raspberry Pi, and more.
Wide Application Range: Ideal for robotics, gaming consoles, remote controls, and any project requiring directional input.
Operating Voltage: 3.3V - 5V
Pin Configuration: - VCC - GND - U_D (for vertical up / down movement) - L_R (for horizontal left / right movement)
Simply power the breakout board using the VCC and GND pins, and connect the U_D and L_R pins to the analog input pins of your microcontroller. As the joystick is moved, the voltage on the U_D and L_R pins will change proportionally, allowing you to determine the joystick's position.
Whether you're building a custom game controller, a robotic arm, or any interactive project, the PSP Analog Joystick Breakout Board offers a straightforward way to add directional control. Dive into the world of intuitive control and endless possibilities with this breakout board!
Enter your email address if you'd like to be notified when PSP 2D Analog Joystick Breakout Board can be shipped to you:
$3.80
$20.50
$17.80
$18.80
$21.30
$13.85
$13.80
$6.50
$8.80
$24.99
$249.99
