10 modular SMD cases with sealing shim for enhanced protection. Transparent lid, compact & versatile. Perfect for electronics enthusiasts.
What is it? Presenting a collection of 10 modular SMD component cases, crafted for the systematic storage and safeguarding of sensitive electronic components. Every case features a custom (resin) 3D-…
Read More…Presenting a collection of 10 modular SMD component cases, crafted for the systematic storage and safeguarding of sensitive electronic components. Every case features a custom (resin) 3D-printed shim that bridges the space between the lid and the case. This unique shim ensures that tiny components, like 0201 passives, remain securely inside even if the case is inadvertently flipped over.
Key Features
Modular Design: The cases are designed to be modular, allowing for easy reconfiguration and organization. Whether you're using them in a workshop, lab, or at home, you can customize your storage solution to fit your needs.
Sealing Shim: Each case comes with a sealing shim that provides an extra layer of protection.
Transparent Lid: The clear lid allows for easy identification of contents without the need to open each case. This not only saves time but also reduces the risk of component damage due to frequent handling.
Compact & Lightweight: The compact design of these cases makes them easy to transport and store. Whether you're on the move or working from a fixed location, these cases are the perfect storage solution.
Versatile Use: While they are designed for SMD components, these cases can also be used to store other small items such as beads, screws, or jewelry.
Easy Access: The flip-lid mechanism ensures that the cases remain securely closed, yet they can be easily opened when required.
Whether you're a professional electronics technician, a hobbyist, or someone who just loves to stay organized, these modular SMD component cases are a must-have. Order yours today and experience the convenience and protection they offer!
Enter your email address if you'd like to be notified when 10 PCS Modular SMD Component Cases w/ Sealing Shim can be shipped to you:
$17.90
$7.80
$17.80
