CUSTOM FLIPPER-ZERO ESP32 MARAUDER BOARD (Plug and Play)
Designed by FlipperHub in Germany
CUSTOM FLIPPER-ZERO ESP32 MARAUDER BOARD (Plug and Play) Price per unit comes without Flipper zero Main Shop Join our discord Specifications: - Custom FlipperAddOns PCB - ESP32: This module is equipp…
Read More…CUSTOM FLIPPER-ZERO ESP32 MARAUDER BOARD (Plug and Play)
Specifications: - Custom FlipperAddOns PCB - ESP32: This module is equipped with Wi-Fi Marauder firmware, which allows you to test your home network for deauth attacks and Wi-Fi password hacking. You can also use it to trick your friends into a rickroll prank.
Compatibility:
This custom module is compatible with all newer versions of Unleashed, Rougemaster, or Xtreme for the Flipper-Zero!
Initial setup: -Download ESP32 marauder app on pinball - plug into the board -done!
Make sure to check my Instagram to be up to date and so you can contact me whenever 🙂 --> @flipper_hub1
⚠️ WARNING ⚠️
Enter your email address if you'd like to be notified when Custom Flipper Zero ESP32 Marauder Plug & play can be shipped to you:
$52.90
$52.90
$11.90
$111.11
$132.00
$112.00 $140.00
$94.00
