A small hardware device for transmitting WSPR messages based on the SI5351 IC.
Designed by Y-Development in Poland
WSPR-beacon 2.0 A small hardware device for transmitting WSPR messages based on the SI5351 IC. The device has a built-in TCXO to eliminate SI5351 frequency drift, a built-in GPS module for operation …
Read More…A small hardware device for transmitting WSPR messages based on the SI5351 IC. The device has a built-in TCXO to eliminate SI5351 frequency drift, a built-in GPS module for operation with active GPS antennas, transmission time synchronization and automatic QTH locator calculation, and a simple amplifier based on a buffer amplifier based on a 74ACT244 IC (PCB version 2.0). PCB is made on based on SMD components and adapted for installation in an aluminum enclosure with dimensions 80 x 50 x 20 mm.
Platform: ATmega328P MCU
Power amplifier: Buffer amplifier based on the 74ACT244 IC
Output RF transformer: Bifilar transformer based on an FT37-43 core
RF connectors: SMA
Feed line: 50 Ohm coaxial cable
GPS antenna type: Active, external
Maximum output power: ~23 dBm
Supply voltage: 5V (USB-B, fuse-protected, 600 mA fuse)
Current consumption:
Standby (GPS antenna not connected): 70 mA;
Standby (GPS antenna connected): 86 mA;
Active TX mode: 96 mA;
Latest firmware version: wspr-beacon-1.1
Supported transmission protocols: WSPR
Configurable via user application: No
Enter your email address if you'd like to be notified when WSPR-beacon 2.0 can be shipped to you:
$179.99
$119.99
$69.99
$179.00
