2Pcs 6-12V DC Motor Double-Shaft Strong Magnetic High Torque Gear Motor for Smart Robot Car/DIY Toys
Designed by XiaoR GEEK in China
🌻Powerful & Quiet Performance – 6-12V DC motor delivers 350 RPM with high torque and low noise, perfect for Smart Cars DIY Toys. 🌻Durable All-Metal Gears – Heat and wear-resistant metal gears ensure …
Read More…🌻Powerful & Quiet Performance – 6-12V DC motor delivers 350 RPM with high torque and low noise, perfect for Smart Cars DIY Toys.
🌻Durable All-Metal Gears – Heat and wear-resistant metal gears ensure long-lasting strength for heavy-duty use in robotics, crafts, and electronics.
🌻Efficient Copper Rotor – Pure copper winding increases conductivity and torque by 30%, providing reliable power for precision tasks.
🌻Secure D-Shaped Shaft – 4mm steel shaft with flat side prevents slipping, making installation easy.
🌻Size - Diameter: 25mm; Shaft length: 12mm; D length 8mm; Shaft diameter: 4mm
Enter your email address if you'd like to be notified when 2Pcs 6-12V DC Motor can be shipped to you:
$989.00
$28.99
$89.00
$79.00
$38.99
$38.99
