A simple assembled USB Type-C adapter board breaks out the power and USB 2.0 data.
Designed by Vlrm.Prjct in GermanyThis product is no longer available for sale.
Made for modular synth modules This simple tiny adapter board breaks out the power and USB 2.0 data and matches perfectly the gap between the pcb ( on surface mount ) and the frontpanel in a modular …
Read More…This simple tiny adapter board breaks out the power and USB 2.0 data and matches perfectly the gap between the pcb ( on surface mount ) and the frontpanel in a modular synth module with thonkiconn jack connectors.
20.0 mm x 10.0mm, Total height: 12.0mm, PCB height: 1.6mm
For surface mounting you have to add a hole with a size of min. 8.5mm in center of the footprint.
This board does not expose the Type-C connector’s USB 3.1 SuperSpeed differential pairs (TX and RX signals), so it only supports USB 2.0 Low-Speed, Full-Speed, and High-Speed communication.
1-2 | $6.90 |
3+ | $6.40 |
$27.60
$16.99
