CUSTOM ESP32 MARAUDER BOARD (Plug and Play)
Designed by The Wired Hatters in GermanyNo shipping info available.
CUSTOM ESP32 MARAUDER BOARD (Plug and Play) Price per unit comes without Flipper zero Main Shop Join our discord Specifications: - Custom PCB - ESP32: This module is equipped with Wi-Fi Marauder firm…
Read More…CUSTOM ESP32 MARAUDER BOARD (Plug and Play)
Specifications: - Custom PCB - ESP32: This module is equipped with Wi-Fi Marauder firmware, which allows you to test your home network for deauth attacks and Wi-Fi password hacking. You can also use it to trick your friends into a rickroll prank.
Compatibility:
This custom module is compatible with all newer versions of Unleashed, Rougemaster, or Xtreme for the Flipper-Zero!
Initial setup: -Download ESP32 marauder app on pinball - plug into the board -done!
Make sure to check my Instagram to be up to date and so you can contact me whenever 🙂 --> @TheWiredHatters
⚠️ WARNING ⚠️
Enter your email address if you'd like to be notified when Custom ESP32 Marauder Plug & play can be shipped to you:
$32.50
$173.25
$49.80
$38.90
$11.90
$11.90
$219.99
$109.99
$104.99
