Power your Flipper Zero effortlessly with our specialized module! It takes the regular 5V power and converts it to the 3.3V needed for the
Designed by The Wired Hatters in GermanyNo shipping info available.
🌟 Introducing the custom "R4BB1T-Hunter" e07-400m10s Module for Flipper Zero! 🌟 Unlock the full potential of your Flipper Zero with our specialized module designed to power the cutting-edge e07-400m1…
Read More…🌟 Introducing the custom "R4BB1T-Hunter" e07-400m10s Module for Flipper Zero! 🌟
Unlock the full potential of your Flipper Zero with our specialized module designed to power the cutting-edge e07-400m10s chip effortlessly and use the 400mhz-450mhz range . Engineered with precision and functionality in mind, this module seamlessly converts the voltage from 5V to 3.3V, ensuring optimal performance of your device.
What sets this module apart is its attention to detail:
🔌 Voltage Conversion: The module efficiently steps down the voltage from 5V to the required 3.3V, enabling seamless and safe operation of the e07-400m10s chip without compromising on performance.
💡 Power LED: Featuring a dedicated power LED, providing a clear indicator of the module's operational status, ensuring convenience and ease of use.
🔊 Noise Reduction: Equipped with top-tier filter capacitors, this module minimizes noise interference, guaranteeing a smooth and uninterrupted power supply to your Flipper Zero.
🌐 Special 4-Layer Stackup: Engineered with a special 4-layer stackup design, the module ensures precise impedance control, optimizing signal integrity for superior performance.
Whether you're a tech enthusiast, developer, or security professional, this module is an essential addition to your Flipper Zero setup. It empowers you to explore the full capabilities of your device with stability, reliability, and unparalleled efficiency.
Upgrade your Flipper Zero experience today with our innovative 5V to 3.3V Converter Module and take your projects to new heights! 🚀✨
The importance of an antenna for this module cannot be overstated. Running the module without an antenna could lead to permanent damage.
Damage caused by incorrect antenna use will be deemed user error and will not qualify for repair or replacement.
⚠️ WARNING ⚠️
This hardware is for educational and experimental purposes only and is not meant for any illegal activity or purposes. I do not condone illegal activity and strongly encourage keeping transmissions to legal or valid educational or experimental uses allowed by law.
Please be advised that the products sold here are third-party items that are compatible with the Flipper Zero. These products are not manufactured, endorsed, or affiliated with Flipper Devices Inc. in any way. The use of the "Flipper" or "Flipper Zero" name in our product descriptions is for identification purposes only, to demonstrate the compatibility of our products with the mentioned device.
Enter your email address if you'd like to be notified when Custom-cc1101 can be shipped to you:
$173.25
$32.50
$49.80
$38.90
$11.90
$20.95
$45.99
$32.50
