A board made for the f0, where you can swap out modules on the run (ebyte CC1101 and NRF24)
Designed by The Wired Hatters in Germany
External Module swap-board for the Flipper-Zero Join our discord This is a custom designed and fully assembled board for the flipper zero that allows the user to swap between either a CC1101 or NRF24…
Read More…External Module swap-board for the Flipper-Zero
This is a custom designed and fully assembled board for the flipper zero that allows the user to swap between either a CC1101 or NRF24 module
Note: 5V GPIO output must be enabled on your Flipper Zero for this module to work.
Compatibility:
This custom module is compatible with all newer versions of Unleashed, Rougemaster, or Xtreme for the Flipper Zero!
All PCB's come with soldered fitting headers
Make sure to check my Instagram to be up to date and so you can contact me whenever 🙂 --> @TheWiredHatters
⚠️ WARNING ⚠️
Enter your email address if you'd like to be notified when 5v Swap-Board (cc1101 & NRF24) can be shipped to you:
$173.25
$32.50
$49.80
$38.90
$11.90
