A powerful 100 watt USB C powered breadboard power supply capable of delivering 5 amps at voltages 5,9,12,15 and 20 with a additional second
Designed by The PCB shop in United Kingdom
A powerful 100 watt USB C powered breadboard power supply capable of delivering 5 amps at voltages 5,9,12,15 and 20 with a additional secondary power rail capable of delivering 1 amp at 5 and 3.3 v…
Read More…A powerful 100 watt USB C powered breadboard power supply capable of delivering 5 amps at voltages 5,9,12,15 and 20 with a additional secondary power rail capable of delivering 1 amp at 5 and 3.3 volts.
ability to select voltages 3.3,5,9,12,15,20 and amperage 1,2,3,4,5 with 2 rails ready to supply a heavy load such as a motor whilst easily supplying your micro controller or other lower voltage electronics with 5 or 3.3 volts.
comes with pins ready to solder, just place the pins in your bread board and then place the power supply on the pins and solder to make the perfect fit. I am open to soldering your pins on in advance if you do not have the ability to solder pins ( just inbox me and il solder them on in advance.).
works with all USB C PD chargers all the way up to 240 watts but this power supply with only deliver up to 100 watts.
works both in standalone mode and external mode, connect pins to the 4 pin header to control the ic yourself, the ic I used was a CYPD3177 and you can find out all the info in the datasheet on how to use the digital control there.
any questions please inbox me as I'm happy to answer them.
Enter your email address if you'd like to be notified when USB C breadboard power supply ( 100Watts ) can be shipped to you:
