ESP32 audio development board with PCM5122 I2S DAC, delivering 2.1V RMS audio with -112dB noise level
What is it The HiFi-ESP32 Plus represents the next evolution of HiFi-ESP32 boards, featuring the advanced PCM5122 DAC with built-in DSP capabilities. This board maintains the same audio quality as th…
Read More…The HiFi-ESP32 Plus represents the next evolution of HiFi-ESP32 boards, featuring the advanced PCM5122 DAC with built-in DSP capabilities. This board maintains the same audio quality as the original HiFi-ESP32 while adding powerful digital signal processing features, including parametric EQ (6 BQs), and DRC. The PCM5122's flexible DSP engine can be configured for various audio enhancement scenarios, making it ideal for projects requiring sound tuning
Key Features:
HiFi-ESP32 is a flexible, open-source audio platform designed to fit into both smart homes and custom audio projects.
| HiFi-ESP32 | HiFi-ESP32-Plus | |
| MCU | ESP32-WROVER-N8R8 or ESP32-S3-WROOM-N8R8 | ESP32-WROVER-N8R8 or ESP32-S3-WROOM-N8R8 |
| DAC | PCM5100A 32bit Stereo DAC (-100 dB typical noise level) | PCM5122 32bit Stereo DAC with integrated DSP (-112 dB typical noise level) |
| Output | Non-amplified stereo output, 2.1V RMS | Non-amplified stereo output, 2.1V RMS |
| Flash/PSRAM | 8MB/8MB | 8MB/8MB |
| Power | 5V over USB-C, 2x LP5907 3.3 V Ultra-Low-Noise LDO for analog section | 5V over USB-C, 2x LP5907 3.3 V Ultra-Low-Noise LDO for analog section |
| Connectivity | WiFi + BT4.2 (except S3) + BLE Ethernet (optional module) | WiFi + BT4.2 (except S3) + BLE Ethernet (optional module) |
| DSP Features | ❌ | Parametric EQ (6xBQ), DRC ** |
| Software support | ||
| Squeezelite-ESP32 | ✅ | ✅ |
| Snapclient | ✅ | ✅ |
| ESPHome (HA) | ✅ | ✅ |
⚠️ HiFi boards require an external amplifier or active speakers; you can't connect passive speakers to it.
💡 Need to connect speakers as well? Check out Amped-ESP32
💡 Need only speakers output? Check out Loud-ESP32
💡 Need more powerful DSP? Check out Louder-ESP32
** Enabling EQ controls in software is a work inprogress
Audio streaming requires proper buffering to work, even with the ESP32's 500K of RAM; it is a challenging task. For that reason, all Louder-ESP32 board versions have an 8 MB PSRAM chip onboard, connected via a high-speed interface.
| I2S CLK | I2S DATA | I2S WS | I2S MCLK (optional) | PSRAM RESERVED | DAC/AMP EN | I2C SDA | I2C CLK. | |
| ESP32 (J) | 26 | 22 | 25 | 0 | 16, 17 | 13 | 27 | 21 |
| ESP32-S3 (H) | 14 | 16 | 15 | 0 | 35, 36, 37 | 4 | 41 | 42 |
| ESP32 (J1+) | 26 | 22 | 25 | 0 | 16, 17 | 13 | 21 | 27 |
| ESP32-S3 (H1+) | 14 | 16 | 15 | 0 | 35, 36, 37 | 4 | 42 | 41 |
| SPI CLK | SPI MOSI | SPI MISO | SPI CS | SPI HOST/SPEED | ETH INT | ETH RST | |
| ESP32 | 18 | 23 | 19 | 05 | 2/20MHz | 35 | 14 |
| ESP32-S3 | 12 | 11 | 13 | 10 | SPI2/20MHz | 6 | 5 |
| IR IN | RGB OUT | OLED SPI HOST/SPEED | OLED SPI CLK | OLED SPI MOSI | OLED SPI MISO | OLED SPI CS | OLED SPI DC | OLED RST | |
| ESP32 | 39 | 12 | 2/20MHz | 18 | 23 | 19 | 15 | 4 | 32 |
| ESP32-S3 | 7 | 9 | SPI2/20MHz | 12 | 11 | 13 | 39 | (37) | 38 |
ESP32-S3 boards have two ways of firmware update: (1) similarly to classing ESP32, they can be flashed over built-in UART, or (2) uniquely for S3, over built-in USB host controller. Since it is firmware-controlled, and may be disabled if not used (or, more commonly, not available with factory default empty firmware). When come unflashed ESP32-S3 device comes into a boot loop, with a USB-CDC device appearing and disappearing every second, and requires a special flashing initialisation sequence to get flashed:
esp_toolPlease visit the hardware section for board schematics and PCB designs. Note that PCBs are shared as multi-layer PDFs, Gerber files, and 3D-models (step files).
Every board has a header that allows soldering in the W5500 SPI Ethernet module that is very easy to find. The only downside is that with the module installed board will not fit the case unless it is cut to accommodate extra height.
| HiFi-ESP32 |
HiFi-ESP32 and HiFi-ESP32-Plus boards are mechanically compatible with Raspberry Pi 4 cases, and they are very easy to source
New restock batches are regularly ordered from the factory, and I plan to keep all versions available at least until the next board revision is released. For current availability, you can also check the official reseller Elecrow.
Due to the new tariffs introduced by the Trump administration, standard shipments are temporarily on hold. However, shipping to the US has now resumed via UPS, though rates are currently quite high. I’ll fully resume regular shipping as soon as the restrictions are lifted. In the meantime, you may consider ordering through Elecrow.
If you’re working on an open-source project, an educational initiative, or any pro-bono/volunteer effort, feel free to reach out for sponsorship details. I’ll do my best to provide discounts or even free boards.
If you’re interested in a custom design based on, or inspired by my boards, I also offer contract design work and consultation when needed.
Enter your email address if you'd like to be notified when HiFi ESP32 Plus can be shipped to you:
| Quantity | Price |
| 1 | $24.00 |
| 2-4 | $23.00 |
| 5-9 | $22.00 |
| 10+ | $20.00 |
$74.00
