Enclosure Box with Mounting Plate 5.5”x3.2
Designed by SMG Designs in United States of America
Project Enclosure Box with Mounting Plate: Key Features: • Optimal Dimensions: Precisely measured at 140mm x 82mm x 62mm (internal depth), providing ample space for complex electronic assemblies • R…
Read More…Project Enclosure Box with Mounting Plate:
Key Features: • Optimal Dimensions: Precisely measured at 140mm x 82mm x 62mm (internal depth), providing ample space for complex electronic assemblies • Robust Construction: 5mm thick walls ensure exceptional structural integrity and long-lasting performance • Versatile Mounting Options: Includes a separate mounting bracket with multiple pre-drilled 4mm tapered screw holes • Quick-Release Design: Enclosure mounts to bracket with 4 8mm Phillips screws, enabling effortless removal while keeping the mounting bracket in place • Secure Closure: Recessed lid held firmly by 4 Phillips 3x6mm screws and threaded inserts • Premium PETG Material: Offers superior impact resistance and clean, professional appearance
Technical Specifications:
External Dimensions: 140mm (5.52in) x 82mm (3.22in)
Internal Depth: 62mm (2.44in)
Wall Thickness: 5mm
Mounting Holes: Multiple pre-configured options
Closure Mechanism: 4 Phillips screws with threaded inserts
Enter your email address if you'd like to be notified when Project Enclosure Box With Mounting Plate 5.5”x3.2 can be shipped to you:
