Arduino Based Developer Enclosure Kit
Designed by SMG Designs in United States of AmericaThis product is no longer available for sale.
Unlock your creativity with the microcontroller Developer Enclosure Kit! Whether you’re just starting out or you’re a seasoned pro, this kit has everything you need to take your projects from concept…
Read More…Unlock your creativity with the microcontroller Developer Enclosure Kit! Whether you’re just starting out or you’re a seasoned pro, this kit has everything you need to take your projects from concept to completion.
This kit is designed for every step of your development journey, making it super easy to keep your work tidy and efficient. Plus, it comes with three quick-change faceplates, so you can switch up your display in seconds! Whether you need a simple LCD readout or a full-on color LCD screen, we’ve got you covered.
Worried about complicated assembly? Don’t be! The lid and baseplate snap together effortlessly, so you can focus on what really matters—bringing your ideas to life. And the best part? All the hardware you need is included, so you won’t be scrambling to find that one tiny screw when you’re in the zone.
Customize your experience by selecting either the ATmega328P or the ESP32 WROOM processor. Both processors are included with individual baseplates and bread board.
Need to power your creation? No problem! The built-in USB port makes it super simple to keep your project running smoothly. Once done programming, simply unplug your USB cable from your processor and plug in included USB cable to your baseplate to power up.
Included in Kit Options: 1 Quick Change Lid that fits all 3 displays 1 Baseplate that fits Arudino UNO boards with threaded inserts and screws. 1 Baseplate that Fits ESP32 Wroom Screw shield board 2 400 Pt. solderless breadboard 1 Screw shield board, 1 for each processor 3 quick change faceplates with included 3x10mm screws for attachment 10 Jumpers 20cm 40 Jumpers 10 cm 1 USB power cable 1 USB programming cable 1 LCD 2004+I2C 20 x 4 display) 1 LCD 1602+I2C 16 x 2 display) 1 2.8" SPI TFT ILI9341 240 x 320 display non touch) 1 R3 ATMEGA 328P processor with screw shield board) 1 ESP32 Wroom processor with screw shield board)
All processors and displays are tested before shipment
