1602 LCD Display Enclosure
Designed by SMG Designs in United States of America
2x16 LCD Enclosure - Durable and Easy-to-Install Case for Standard 1602 LCD Displays Our enclosure features a sleek and compact design, measuring 66mm in width, 125mm in length, and 19mm in depth. Th…
Read More…2x16 LCD Enclosure - Durable and Easy-to-Install Case for Standard 1602 LCD Displays
Our enclosure features a sleek and compact design, measuring 66mm in width, 125mm in length, and 19mm in depth. The 10mm side hole with a removable hole plug allows for easy wire management, keeping your workspace organized and clutter-free. The enclosure is made of durable PETG plastic, with a 3mm thick case that provides excellent durability and protection for your LCD display.
The enclosure comes with four 3mm x 6mm screws for securing the display to the faceplate, and four 3mm x 10mm screws for attaching the faceplate to the bottom enclosure. This ensures a sturdy and stable setup that can withstand regular use. The faceplate is attached to the enclosure via four screws, making it easy to install and remove.
Versatile and Convenient
The 2x16 LCD Enclosure also features two 4mm recessed screw holes for panel mounting, allowing you to easily integrate it into your project or application. The outer extended rim of the enclosure makes installing the faceplate a simple and hassle-free process.
What's Included:
2-piece box and faceplate design
4 x 3mm x 6mm screws for securing display to faceplate
4 x 3mm x 10mm screws for securing faceplate to bottom enclosure
Removable hole plug for wire management
Specifications:
Enclosure width: 66mm
Enclosure length: 125mm
Enclosure depth: 19mm
Side hole diameter: 10mm
Case thickness: 3mm
Screw hole diameter: 4mm
Enter your email address if you'd like to be notified when 2x16 LCD Display Enclosure can be shipped to you:
$51.98
$14.99
$46.00
$11.39 $11.99
