an integrated driver board for low-pressure xenon plasma toroids
Designed by sky-guided designs in United States of America
Limited stock. If stock has run out, "Join waitlist" ↗ for an email notification on re-stocks. This listing is for a electronics KIT, not a finished product. Please read the full description! yes, i…
Read More…Limited stock. If stock has run out, "Join waitlist" ↗ for an email notification on re-stocks.
yes, it really does look like the photos.
This is a device for creating low-pressure xenon plasma toroids. By generating an oscillating, high-voltage radiofrequency magnetic field, xenon gas is wirelessly ionized into an inductively-coupled plasma.
Other enthusiasts have built similar toroid drivers, but mine has some special features:
The sky-guided plasma toroid is an open-source project. Full documentation, schematics, component lists, fabrication files, and more are available in the Codeberg repository.
This listing is for a plasma toroid driver kit, not a finished product. You'll need to obtain a suitable xenon globe, 3D print the support structure, hook up a power source, and do some minor mechanical assembly.
This is an experimental radiofrequency device. Do not leave it running unattended, and do not run near any sensitive or safety-critical electronics (including personal medical devices). Some areas of the board have potential to cause shock/burn if touched during operation.
Enter your email address if you'd like to be notified when sky-guided plasma toroid driver board can be shipped to you:
Packages may take up to five days to ship.
