Drone Boy is triple reverse avalanche oscillator.
Designed by DIYSynths&Sounds in CzechiaNo shipping info available.
Drone Boy is triple reverse avalanche oscillator with interchangeable capacitors to alter the pitch. Demo I Demo II • Three SS9018 transistors • Powered by 9V • Power Jack 5.5/2.1 (Center positive) …
Read More…Drone Boy is triple reverse avalanche oscillator with interchangeable capacitors to alter the pitch.
• Three SS9018 transistors • Powered by 9V • Power Jack 5.5/2.1 (Center positive) • Comes with bunch of capacitors • LM386 pre amp • 3.5mm Stereo Output Jack
• Size is 3.5"x 2" (8.9 x 5.1 cm) • Black or White PCB • Rubber feet attached on the bottom • Comes with 9V battery adapter
Enter your email address if you'd like to be notified when Drone Boy can be shipped to you:
$5.50
$27.99
$23.00
