BME690 Breakout Board – Environmental & Gas Sensor – I2C – 17x17 mm – Qwiic/Stemma QT Connector – 3.3V & 5V Compatible
Designed by rwx Lab in GermanyNo shipping info available.
The BME690 Breakout Board is a compact and powerful sensor module for precise environmental measurements – perfect for smart electronics projects. Based on the Bosch BME690 it measures: 🌡️ Temperatur…
Read More…The BME690 Breakout Board is a compact and powerful sensor module for precise environmental measurements – perfect for smart electronics projects.
🌡️ Temperature 💧 Humidity 🌀 Air Pressure 🧪 Gas Quality / IAQ – including VOC detection
With dimensions of just 17 x 17 mm, it fits into any project. The integrated Qwiic/Stemma QT connector allows for tool-free connection via I²C, making it ideal for rapid prototyping and space-constrained applications.
🌡️ Multi-Sensor for Precise Environmental Monitoring: Measures temperature, humidity, air pressure & gas quality (IAQ) using advanced BME690 technology.
⚡ I²C Interface with Qwiic/Stemma QT Connector: Quick integration via I²C – no soldering required thanks to the 4 Pin JST PH connector.
💡 Versatile Use: Compatible with Arduino, ESP32, Raspberry Pi & more – perfect for air quality monitoring, weather stations & IoT projects.
🔋 3.3V & 5V Compatible: Fully supports both 3.3 V and 5 V systems for power and signal levels – making it ideal for almost all microcontroller platforms such as Arduino, ESP32, Raspberry Pi, STM32, Teensy, and more.
🔧 Ultra-Compact & Powerful: Just 17 x 17 mm – perfect for small projects and mobile applications.
Applications: Indoor air quality monitoring, smart home, weather stations, IoT, mobile sensor solutions, environmental analysis, and much more.
Enter your email address if you'd like to be notified when BME690 Breakout Board can be shipped to you:
| Quantity | Price |
| 1-9 | $29.95 |
| 10+ | $24.99 |
$24.95
$23.97
$26.99
