ABZ Quadrature Adder/ Subtractor – Eases Direct Axis Position Feedback for Differential Drive Kinematics
Designed by Rowdy_NPC_Shop in Japan
Your CoreXY doesn't have to compromise on accuracy, nor speed! Mount linear encoders on the physical X/Y axes, mix signals in pure hardware, and feed perfect motor-domain A/B feedback to your control…
Read More…Mount linear encoders on the physical X/Y axes, mix signals in pure hardware, and feed perfect motor-domain A/B feedback to your controller.
No firmware hacks, no CPU overhead, no more VFAs!
This compact hardware module mixes two independent ABZ quadrature encoder signals (e.g., linear X and Y) in real time:
Plug your axis encoders in → get the clean, low-latency ABZ signals your motion controller expects.
Most motion controllers (Duet3 1HCL, ODrive, many industrial servos) expect encoder feedback to match each motor's rotation. In CoreXY and differential-drive systems, this creates issues:
Result: You sacrifice true positional accuracy or fight hardware/firmware limitations and performance penalties.
The fix is hardware-level mixing, transforming linear X/Y feedback into motor-domain A = X+Y and B = X-Y signals, so your existing controller sees exactly what it wants, with zero software involved.
Standard kit includes all crimp connectors.
Works out of the box with most quadrature encoders.
Hardware-only processing eliminates software sensor fusion delays.
Lab tested up to full spec ー see scope traces below.
Trick industrial servo drives and single-encoder-per-axis controllers into thinking they’re driving a standard Cartesian stage: perfect for retrofitting CoreXY mechanics!
| Parameter | Value |
| Absolute Min. / Max. Supply Voltage | -0.5 ~ 7.0 V |
| Operating Voltage (Vdd) | 3.3 V ±0.3 V ~ 5.0 V ±0.5 V (<100 mA) |
| Min. Propagation Delay | 73 ns @ 5.0 V / 112 ns @ 3.3 V |
| Min. Output Edge Separation | 67 ns (17.0 MS/s minimum recommended sampling rate) |
| Max. Error-free Bitrate* per input | 6.0 Mbps (185ns minimum recommended input edge separation) |
| Output Type | Single-ended TTL push-pull (<9 mA, 50~65 Ohm) |
| Inputs | Single-ended TTL (10 kΩ internal pull-up to VDD) |
| Z Output | XOR of Z_x and Z_y |
| Operating Temperature Range | -20°C to 65°C |
| Included | ・ 4 x CDR-05-TS header (soldered / unsoldered opt.) |
| ・ 4 × CDH-05 plugs | |
| ・ 20 × CDH-C crimp contacts |
*Error rate < 0.001 ppm
For best performance:
Each sold unit is individually tested for error-free processing of at least 1 Gib of data simultaneously streamed to both ABZ inputs of the mixer at the combined inputs' Max. Error-free Bitate at 3.3V.
Shipping worldwide from Japan* via Tindie. For the relevant destinations, import tariff is not included in the listed price of the goods
Special Launch Price: $42 for the first 12 units
(because sometimes the answer really is 42 😉 – after that, regular price $55).
Questions about:
- Signals over differential pairs?
- Higher/Lower speed variants?
- I/O signals galvanic isolation?
- Other?
➡️ Message me!
Happy to help with concerns regarding wiring, integration, or shipping.
THANK YOU! For supporting a small hardware maker! 🚀
Enter your email address if you'd like to be notified when Encoder Mixer for Closed-Loop CoreXY / Diff. Drive can be shipped to you:
