AC Dimmer Board that is controlled by a PWM signal or a 0V to Vcc (5V Max) signal (microcontroller, potentiometer or any arduino)
Designed by RF Simplicity in Canada
Features: Dimmer Board for selecting any voltage between 0 VAC - 120 VAC or 0 VAC - 240 VAC Automatically detects 50Hz or 60Hz line frequencies! On-board micro-controller. No programming required…
Read More…Features:
Example uses: Control the speed of a fan, drill, motor, etc. Dim lights. Control temperature using a heater. Brewing beer. Maintaining a set-point using AC, etc.
Triac rated for:
*RMS currents of higher than 8A will need external cooling like from that of a fan which can be plugged into the fan header.
Controls the amount of dimming based on an input voltage on the CTRL pin or a Pulse Width Modulation (PWM) signal.
[ Connections: ]
Choose the mode by using the 'Mode' pin:
Ground = Voltage Mode
3.3V / 5V = PWM Mode
For Voltage/Analog Mode (using a potentiometer- ie. variable resistor):
Voltage Amount of Dimming
0.00V - Vcc: 100% - 0% Dim (Based on 'CTRL' Voltage)
Arduino Dimmer Board Breadboard
CTRL 'wiper' (middle pin) of potentiometer
5V 5V First leg of pentiometer
GND GND Other leg of potentiometer
PWM Mode:
Duty Cycle Amount of Dimming Arduino Code
0 - 5% 100% Dim (Fully OFF) analogWrite(0) to analogWrite(15)
5%-40%: 100% - 0% Dim analogWrite(15) to analogWrite(90)
Greater than 40%: 0% Dim (Fully ON) analogWrite(90) to analogWrite(255)
5V 5V
5V MODE
GND GND
Digital Pin 9 (PWM or any PWM pin) PWM
Github Repository Downloads:
Arduino PWM Dimming example sketch
Arduino PWM Serial Control example sketch
Control using a HC-05 Bluetooth Module and an Arduino via an Android phone or tablet:
While high voltage systems are interesting experimentally, they can be dangerous, and if not treated with care, respect and intelligence, they can result in a fatal injury.
| Quantity | Price |
| 1 | $22.00 |
| 2-3 | $20.00 |
| 4+ | $18.00 |
Product: (4.09)
Documentation: (3.55)
Shipping: (3.91)
Communication: (4.00)
Brad | March 17, 2019
William | Sept. 5, 2018
Sean | Aug. 28, 2018
Daniel | Sept. 29, 2017
Miguel | June 28, 2017
Denver | Sept. 21, 2016
Lewis | July 3, 2016
James | April 22, 2016
Morten | Jan. 26, 2016
Edward | Jan. 17, 2016
Jeff | March 10, 2015
