0.8-Inch 48×64 transparent LCD with SPI Interface - perfect for projection, AR optics, or layering visuals over real-world views.
What is it? Unveil a new dimension of display technology with the 0.8-inch Transparent 48x64 LCD SPI Display Module, featuring a 48×64 pixel resolution and black-pixel rendering on a fully see-throug…
Read More…Unveil a new dimension of display technology with the 0.8-inch Transparent 48x64 LCD SPI Display Module, featuring a 48×64 pixel resolution and black-pixel rendering on a fully see-through background. This compact screen breaks free from the limitations of traditional opaque displays, offering a crisp monochrome image while allowing the background to remain visible—perfect for layering visuals in creative and technical applications.
With no built-in backlight, the module is ideal for optical projection: simply shine a bright LED through the screen to cast detailed silhouettes of your display content onto a nearby surface. The black pixels selectively block light, making this tiny LCD an excellent candidate for miniature projection setups and other imaginative use cases.
Key Features:
This module has the following pinouts:
You can use the following open source Arduino Library: ST7565_0.8_TRANSPARENT_LCD
Innovative Use Cases:
Projection Displays: Shine a high-brightness LED through the screen to project content onto walls, diffusers, or even holographic film surfaces. Perfect for micro signage, wearable projectors, or sci-fi inspired props.
Augmented Optics: Integrate into optical systems like smart glasses, HUDs, or AR viewfinders where overlaying graphics on the real world is crucial.
Embedded Interfaces: Add dynamic display elements to clear acrylic panels, model kits, or compact devices where traditional screens would obstruct design aesthetics.
Retro-Tech & Cyberpunk Builds: Bring your futuristic creations to life with a floating display effect reminiscent of vintage HUDs and CRT overlays.
Whether you're developing a futuristic wearable, an artistic installation, or an experimental user interface, this transparent LCD opens up creative pathways that opaque displays simply can't.
Enter your email address if you'd like to be notified when 0.8" Transparent 48x64 LCD SPI Display Module can be shipped to you:
$38.80
$23.80
$24.80
$12.80
$2.50
$17.80
$13.80
$17.99
$11.39 $11.99
$49.99
