Matrix Router Breadboard capabale of connecting 126 nodes into 15 nets
Designed by Protomatrix in United States of America
What is it? Protomatrix is an advanced matrix router breadboard designed for reproducible prototyping of electronic circuits. Protomatrix breadboard has a build-in matrix router that allows you to ma…
Read More…Protomatrix is an advanced matrix router breadboard designed for reproducible prototyping of electronic circuits. Protomatrix breadboard has a build-in matrix router that allows you to make connections without use of jumper wires. Each matrix crosspoint is implemented as a solder jumper that can be closed by applying a small amount of solder.
I made it after learning about matrix routing algorithms used in high-end PXI switching matrices in test equipment. I realized I could build a matrix switching architecture into the humble breadboard!
It allows you to just randomly solder a bunch of parts into the board and then connect them in arbitrary ways by following a simple algorithm:
Custom board sizes can be ordered (MOQ 5 PCBs). The board is auto routed using specialized software. I can generate a matrix board of any size with-in minutes for your needs. Gerber files available on request.
Enter your email address if you'd like to be notified when Protomatrix 2x63x15 (Qty 2) can be shipped to you:
