Tilswall rotary tool kit with 145pcs accessories, covering all needs of carving, grinding, milling, polishing, drilling, sanding.
Designed by Tilswall in Germany
Tilswall rotary tool kit with 145pcs accessories, covering all needs of carving, grinding, milling, polishing, drilling, sanding, and engraving. High-quality multifunctional rotary tool for wood, pla…
Read More…Tilswall rotary tool kit with 145pcs accessories, covering all needs of carving, grinding, milling, polishing, drilling, sanding, and engraving. High-quality multifunctional rotary tool for wood, plastic, jewelry, gypsum board, laminate, and aluminum and vinyl siding, it's ideal for multipurpose cutting.
160w electric rotary tool with pure copper motor, it supports variable 6 level speed 8000-33000RPM, meet the requirements of diy; handle with led light can work clearly in dark, and the auxiliary handle can realize precise operation.
Covering all needs of cutting, grinding, milling, cleaning, polishing, drilling, sanding, and engraving. high-quality multifunctional milling cutters can easily cut wood, plastic, fiberglass, gypsum board, laminate, and aluminum and vinyl siding, it‘s ideal for multi-purpose cutting.
Instead of ordinary sand ring, our sand ring of alumina abrasive is bonded with a dense emery cloth to solve the problem of cracking in use. 3-jaw sandwich core made of tin bronze chuck is more flexible than conventional aluminum, which fits tightly to the handle of the accessory and improves the concentricity, ensuring that there is no shaking during use.
Made from soft rubber, this rotary tool is more comfortable to use for a long time. the abrasive buff with handle is very suitable for use on metal, glass, wood, aluminum and plastic, and can easily remove rust on brass.
Re-designed storage bag is convenient for placing accessories and preventing damage to the machine from falling.
For more information, please visit our website: Tilswall rotary tool kit
Enter your email address if you'd like to be notified when Tilswall Variable Speed Rotary Tool Kit can be shipped to you:
Free shipping on orders over €19.99
$199.00
$229.00
$79.00
$2.95
