8ch 100Mbps Bidirectional Push-Pull / Open-drain Voltage Translator, Level-Shifter Adjustable from 1.5V-5.0V
Designed by PNP Instruments in United States of America
The 8ch translator is an 8-bit non-inverting level shifter/translator. The translator is capable of push-pull speeds up to 100Mbps or open-drain to speeds of 2Mbps. The “B” side of the translator ca…
Read More…The 8ch translator is an 8-bit non-inverting level shifter/translator. The translator is capable of push-pull speeds up to 100Mbps or open-drain to speeds of 2Mbps. The “B” side of the translator can be set from 1.8V to 5V. The “A” side of the translator can be set from 1.5V to 3.3V with the DIP switches on the board. Signals can be applied to the pin headers and/or the terminal post.
Applications
TTL level shifting CMOS level shifting SPI/UART/CAN/etc. level shifting I2C / I3C level shifting
Operation
Plug in any USB-C cable capable of supplying 5V with at least 100mA of current capability. (most USB interfaces can provide this with no issue). The blue LED near the USB connector will light up to indicate the board is powered. The possible switch configurations for the various voltages are shown below in Table 1. It is always required that Bank B side of the translator always have its voltage set equal or higher than Bank A side of the translator. Device will not be damaged if set wrong, just will not work properly as a translator.
Specifications
Electrical characteristics can be found in the datasheet for Part Number: TXS0108E Manufacturer: Texas Instruments
Weight: 0.73oz / 21g
Dimensions: 1.93x1.48x0.68" /48.9x17.7x17.3mm
Enter your email address if you'd like to be notified when 8ch 100Mbps Bidirectional Voltage Translator can be shipped to you:
All shipments, by default, will be handled by USPS. All orders received before 12pm (PST), will be shipped out the same day. A tracking code will be provided.
For International packages, please check with your own country's customs regulations before purchase. We will fill up all the customs-required information when we ship out but we do not handle custom clearance at the destination country.
$120.00
$140.00
$11.99
$13.00
