Adjustable Step-Down Regulator 4.5-36 V with Selectable Voltage Output: 3.3, 5, 9 or 12 V up to 2.5 A continuous current.
Designed by PN Labs Inc. in Canada
The PN Labs NanoBuck is a highly-integrated adjustable step down voltage regulator that is perfect for powering peripherals that need to operate over a 4.5-36 V input voltage range. Since you can eas…
Read More…The PN Labs NanoBuck is a highly-integrated adjustable step down voltage regulator that is perfect for powering peripherals that need to operate over a 4.5-36 V input voltage range. Since you can easily change the output voltage by using the onboard jumpers, it is very easy to reuse this module in multiple projects, saving you tons of money by not having to purchase a pile of different conventional regulators.
Its features include:
Using inductor-less switching technology, the NanoBuck boasts high efficiencies of 80-95% at continuous currents of up 2.5 A with the supplied heatsink. The actual current achievable depends on the ambient temperature, input voltage, and whether you attach the supplied heatsink. See the supplied graph for more details.
Why Integrated Inductor Technology is better: Unlike conventional buck regulators that rely on bulky external inductors, integrated inductor technology embeds the inductor directly into the package alongside the controller and switching elements. This integration reduces PCB footprint, increases power density, and simplifies board layout by eliminating the critical high-current loop from the external design.
With the inductor shielded and internally packaged, parasitic resistance and inductance are minimized, enabling higher switching frequencies with lower losses and improved transient response. The result is better efficiency, reduced radiated EMI and an overall smaller footprint. This IC also incorporates Dual Random Spread Spectrum (DRSS) technology to reduce EMI peaks.
Still have questions? Our customer support is support@pnlabs.ca. Send us an email and be as descriptive as possible.
Enter your email address if you'd like to be notified when NanoBuck: 3.3, 5, 9, 12 V Adjustable Regulator can be shipped to you:
Ships next day if in-stock, through Canada Post/USPS or UPS. Shipments are delivered without duty paid (DDU) unless you contact us to arrange payment of duties beforehand, as the Tindie marketplace does not offer a way of estimating them before the order is placed.
| Quantity | Price |
| 1-4 | $16.99 |
| 5-9 | $15.99 |
| 10-24 | $15.49 |
| 25+ | $14.49 |
$23.99
$23.99
$20.99
$59.95
$33.00
$39.98
$54.00
