Genuine BAK N21700CG-50 21700 High-Capacity Li-ion Cells (5 Ah, 3.6 V, 10 A)
Designed by PCB Studios in United States of America
These are genuine BAK N21700CG-50 battery cells. They are not pulls, rewraps, or recycled cells. BAK is an established manufacturer that supplies cells for major e-bike and energy storage brands. The…
Read More…These are genuine BAK N21700CG-50 battery cells. They are not pulls, rewraps, or recycled cells. BAK is an established manufacturer that supplies cells for major e-bike and energy storage brands. These are perfect for battery pack builds, solar installs, e-bikes, and DIY power projects.
The backstory for these particular cells is they were purchased by an EV battery company that hoped to build hot-swappable battery packs for EVs to minimize charging times. As fast charging has gotten faster and faster, I don't think that panned out that well.
Each cell will arrive pre-charged to ~3.6V
> ⚠️ Disclaimer: Lithium ion batteries may explode or burn due to improper use. Using these batteries for purposes not intended by the manufacturer, including outside a battery pack and/or without a BMS, may cause severe injury and damage. I am not responsible for any injuries caused by lithium ion batteries - use at your own risk.
Enter your email address if you'd like to be notified when 5000mAh 21700 Battery Cells can be shipped to you:
1-9 | $4.00 |
10-14 | $3.75 |
15-19 | $3.50 |
20-24 | $3.25 |
25-29 | $3.00 |
30-39 | $2.75 |
40+ | $2.50 |
$24.99
$2.99
$3.99
$350.00
$76.86
$9.95
