Micro AR Display 1.3 inch 3552x3552 hjgh resolution 1600nits MIPI i2c interface OLED Microdisplay for AR/Head-mounted display
Product Overview This display is a 1.3 inch diagonal, 3552× 3552 dots active-matrix color OLED module based on single-crystal silicon transistors, this 1.3 inch micro oled display panel with FHD 3552…
Read More…Product Overview
This display is a 1.3 inch diagonal, 3552× 3552 dots active-matrix color OLED module based on single-crystal silicon transistors, this 1.3 inch micro oled display panel with FHD 3552× 3552 High resolution and high luminance level up 1600cd/m2, popular used in virtual devices such as AR Glasses and VR Headset, thanks to its micro Si-OLED (Silicon Organic Light Emitting Diode) technology, this micro screen is with very impact size, light weight and low power consumption, also applicable for the medical and military industry such as Head-mounted Displays (HMD),viewfinder,Head-Mounted Displays (HMD) etc.
Applications: View finders, Head mounted displays, etc.
1.3 inch Si-OLED micro display Parameter
1.3 inch Micro OLED 3552x3552 Features:
Interface - --MIPI-DSI (Display Serial Interface) interface with 2 ports(8 lanes) - --Only support video mode,only support Non-burst mode sync with events and Non-burst mode sync with pulses - --MIPI data rate up to 1.65Gbps - --I2C interface
Fail indicator:
Power Requirement:
Dimension
1.3 inch 3552x3552 Micro display Screen Applications:
Enter your email address if you'd like to be notified when 1.3 inch Microoled Display 3552×3552 1600NITS MIPI can be shipped to you:
$255.97
$229.00
$135.00
$238.00
$105.00
$219.00
$185.00
$479.00
$185.00
$629.00
$469.00
$199.00
