Sony ECX331D 0.5 Inch 1024x768 OLED Display 500cd/m² Small Amoled With HDMI Driver Board For HMD AR VR
Overview This Micro display is a1.3 cm (0.5 type) 0.5 inch in diagonal active matrix color OLED panel module uses single crystal silicon transistor. this 0.5 inch oled microdisplay module features a …
Read More…Overview
This Micro display is a1.3 cm (0.5 type) 0.5 inch in diagonal active matrix color OLED panel module uses single crystal silicon transistor. this 0.5 inch oled microdisplay module features a high resolution of 1024x768 and up 500cd/m2 high luminace. The panel adopts panel drive and logic drive to achieve small size, light weight and high definition. It enables NTSC/PAL progressive system of full color display.
This micro screen has no 3D display function.Application: viewfinder, video glasses, head-mounted display, etc.
Parameter for the 0.5" 1024x768 Micro screen:
Dimension of 0.5" 1024x768 Micro screen:
Display Driver Board solution OPTIONS:
Optical lens OPTIONS for 0.5" 1024x768 Micro screen:
OPE05-12X
OPE05-12XN
Feature of 0.5" micro oled screen
Applications fields of the 0.5" micro oled screen
Enter your email address if you'd like to be notified when 0.5 INCH MICRO AR VR Display 1024x768 RGB can be shipped to you:
$185.00
$255.97
$229.00
$135.00
$238.00
$479.00
$105.00
$185.00
$539.00
$149.00
$256.00
$279.00
