Sony ECX331D OLED MICRODISPLAY 0.5 Inch 1024x768 RESOLUTION 500cd/m² MICRODISPLAY With HDMI Driver Board For HMD Night Vision
Overview This Micro display is a1.3 cm (0.5 type) 0.5 inch in diagonal active matrix color OLED panel module uses single crystal silicon transistor. this 0.5 inch oled microdisplay module features a …
Read More…Overview
This Micro display is a1.3 cm (0.5 type) 0.5 inch in diagonal active matrix color OLED panel module uses single crystal silicon transistor. this 0.5 inch oled microdisplay module features a high resolution of 1024x768 and up 500cd/m2 high luminace. The panel adopts panel drive and logic drive to achieve small size, light weight and high definition. It enables NTSC/PAL progressive system of full color display.
This micro screen has no 3D display function.Application: viewfinder, video glasses, head-mounted display, etc.
Parameter for the 0.5" 1024x768 Micro screen:
Feature of 0.5" micro oled screen
Dimension of 0.5" 1024x768 Micro screen:
Optical lens OPTIONS for 0.5" 1024x768 Micro screen:
Applications fields of the 0.5" micro oled screen
Packing Listing:
Enter your email address if you'd like to be notified when 0.5 inch OLED Microdisplay 1024x768 RGB for AR can be shipped to you:
$435.00
$579.00
$449.00
$342.00
$109.00
$489.00
$109.00
$539.00
$539.00
$219.00
$149.00
$279.00
