New gaskets for resealing your controller after surgery
Designed by MK Lighting in Czechia
If you open the Onewheel controller box, you will need fresh gaskets to seal it again correctly. Double-sided gaskets are made of 3M 5962F VHB, ~1m thick. Set of two for both 16 and 6 pin Molex conne…
Read More…If you open the Onewheel controller box, you will need fresh gaskets to seal it again correctly. Double-sided gaskets are made of 3M 5962F VHB, ~1m thick. Set of two for both 16 and 6 pin Molex connectors.
Outer dimmesions: large - 82x31 mm, small - 51x31 mm
Made in CZ
$28.00
$88.00
$38.99
$34.00
