New gaskets for resealing your controller after surgery
Designed by MK Lighting in CzechiaThis product is no longer available for sale.
$139.00
If you open the Onewheel controller box, you will need fresh gaskets to seal it again correctly. Double-sided gaskets are made of 3M 5962F VHB, ~1m thick. Set of two for both 16 and 6 pin Molex conne…
Read More…If you open the Onewheel controller box, you will need fresh gaskets to seal it again correctly. Double-sided gaskets are made of 3M 5962F VHB, ~1m thick. Set of two for both 16 and 6 pin Molex connectors.
Outer dimmesions: large - 82x31 mm, small - 51x31 mm
Made in CZ
$199.98
$28.00
$88.00
