Sensor board containing ICM-42670-P - Accelerometer, Gyroscope, Motion Tracker, IMU
Designed by LEK Electronics in Singapore
What is it? The ICM42760P Motion Tracker Board is a compact, high-performance sensor module built around the TDK InvenSense ICM-42760-P — a high performance 6-axis MEMS MotionTracking IMU. It integra…
Read More…The ICM42760P Motion Tracker Board is a compact, high-performance sensor module built around the TDK InvenSense ICM-42760-P — a high performance 6-axis MEMS MotionTracking IMU. It integrates a 3-axis gyroscope and a 3-axis accelerometer in a single package, delivering precise motion and orientation data for a wide range of applications.
Key Applications:
Wearables: fitness bands, smart watches
Gaming: motion-enabled controllers
Consumer electronics: smart TV remotes
Drones and UAVs
Robotics and automation systems
Featuring:
On-board 3.3V regulator – easy power integration
10-pin, 2.54 mm pitch header for power and signal connections
Multiple host interfaces: I²C, SPI, and I³C
User-selectable gyroscope range: ±250 to ±2000 dps
User-selectable accelerometer range: ±2 g to ±16 g
Finding an affordable, simple, ready-to-use evaluation module for the ICM-42760-P was not so easy — so I made one myself. This small lightweight board is designed to make testing, prototyping, and integrating this powerful motion sensor quick and hassle-free.
Enter your email address if you'd like to be notified when ICM-42670P Module can be shipped to you:
$13.50
$5.20
$2.00
$2.00
$8.50
