Precision Digital Inductance and Capacitance Meter
Sold By JasonKits QRP
L/C/CE Meter – Precision Inductance, Capacitance, and ESR Meter Measure L, C, and CE Electrolytic capacitors with High Accuracy! The L/C/CE Meter is a versatile, open-source handheld instrument desig…
Read More…L/C/CE Meter – Precision Inductance, Capacitance, and ESR Meter
Measure L, C, and CE Electrolytic capacitors with High Accuracy! The L/C/CE Meter is a versatile, open-source handheld instrument designed for measuring inductance (L), capacitance (C), and Electrolytic capacitors up to 10,000uf with high precision. Perfect for electronics hobbyists, repair technicians, and engineers!
Key Features:
✅ Wide Measurement Ranges:
Inductance (L): 0.1 µH – 1 H
Capacitance (C): 1 pF – 10,000 µF (Including Electrolytic and Tantalum Capacitors)
✅ High Accuracy & Resolution
Has Calibration Menu
Has Compensation Menu
3 Modes toggles from L to C to CE
Auto-indication from nh - mh - h and pf - nf -uf for ease of use
Stable and reliable readings
✅ LCD Display
Clear, easy-to-read measurements on 2 x 16 LCD
Compact and portable design - can be powered from 9v -12v Battery
Open Source and Fully documented on OSHWLab (All credits to Wegi)
✅ Standard 2.1mm DC Power Input
Compatible with common AC/DC power supplies 9 -12V Input
Who Is This For? ✔ Electronics hobbyists – Test components for your DIY projects ✔ Repair technicians – Quickly check capacitors and inductors ✔ Engineers & makers – A handy bench tool for prototyping
I have also designed an enclosure for this project.
What’s Included?
Assembled & tested L/C/CE Meter
Power adapter not included (uses standard 2.1mm DC jack)
Enter your email address if you'd like to be notified when Precision AVR Inductance/Capacitance Meter can be shipped to you:
$59.00
$69.98
$53.00
$134.99
$299.00
$13.80
