PI Pico Function Generator
Sold By JasonKits QRP
What is it? The AWG is a simple function generator based around a raspberry pi pico with its digital pins wired to a simple r-2r Resistor ladder forming a DAC-Digital analog converter. an opamp stage…
Read More…The AWG is a simple function generator based around a raspberry pi pico with its digital pins wired to a simple r-2r Resistor ladder forming a DAC-Digital analog converter. an opamp stage and a push-pull stage is also included so as to provide a good output signal with a amplitude of +/-12v
2.8" tft display
Rotary encoder with 2 buttons up and down to shuffle the options
Frequency range: 20Hz - 20MHz sine wave (not all wave forms work nicely up to 20MHz)
DAC resolution 8-bit or 10-bit
Output switches for AC/DC coupling and output resistance Zout low/50Ohm
Output Voltage 6Vpp no load, 2.8Vpp with Zout switch to 50Ohm and 50 Ohm termination
Wave forms: sine, pulse (saw tooth, triangle, square wave), Gaussian, sinc, exponential, noise
Op-Amp Buffered and Transistor Pushpull output stage.
Dedicated split Power supply
Remote control of the awg with appropriate software.
Printed circuit boards : Mainboard and power supply boards
Enter your email address if you'd like to be notified when Pi Pico Arbitrary Waveform Generator can be shipped to you:
$59.00
$69.98
$53.00
$42.00
$27.00
