Solid state discreet Audio Amplifier
What is it? Mini Discrete Audio Amplifier Kit The mini discrete amplifier is an easy-to-assemble kit, perfect for beginners. It runs on a DC supply from 3V (with lower output) up to 18V and offers a…
Read More…Mini Discrete Audio Amplifier Kit The mini discrete amplifier is an easy-to-assemble kit, perfect for beginners. It runs on a DC supply from 3V (with lower output) up to 18V and offers a voltage gain of ~40dB (65dB power gain into 8Ω), matching the LM386’s performance but with less noise and hiss. At +12V, it delivers up to 0.5W into an 8-ohm load. Note: This is a high-gain circuit—keep input wires short and well-routed. A 1mV (Hi-Z) input yields 50mV output at 8Ω, and distortion begins around 1V RMS output.
I wanted a simple audio Amplifier for one of the ongoing radio projects and did not want to use an audio chip and so i built this simple circuit. It works Just fine and Noise is very low and audio output is very clear and crisp.
The amplifier was designed on a 2 sided screened board to keep the amplifier stable and away from oscillations and from any RF noise. It is very easy to build and use , consumes very little current and can be powered from 3 (with a lower output) to 18v (0.5w )
What is Included
Full Un assembled Kit with all parts and PCB and Instruction sheet.
Enter your email address if you'd like to be notified when Discrete Audio Amplifier can be shipped to you:
$59.00
$69.98
$53.00
$9.50
