A board that makes it easy and fast to change from one project/setup to another
Designed by itoffice_eu in SpainThis product is no longer available for sale.
ITEM A PCB of 110x100mm size without further components. What is it? A convenient and flexible platform for stable sensor projects Why did you make it? Breadboard experiments aren't stable when you p…
Read More…A PCB of 110x100mm size without further components.
Breadboard experiments aren't stable when you physically move them around for storing or for use on another place. This PCB is the base platform for stable development and use of sensors and electronics. You develop, attach and exchange extension boards as you like and need, and as often as you like. No cables suddenly falls of and leaves you with a puzzle for getting it running again.
It is the carrier platform for infinite many different extension boards. Those you buy, or those you build yourself.
Make sensors a question of minutes.
Never again lose your builds and experiments because of lose or missing wiring. Fix and secure your breadboard experiments in a robust way for long time. Go straight to industrial grade roughness.
Solder header pins on and combine the board with extension boards from my shop and start collecting different sensor data in minutes.
Easily exchange, improve and update extension boards.
1-9 | $19.95 |
10+ | $11.95 |
