A DIY split keyboard based on the Half-Swept.
Designed by haxwell in Australia
This is a 34-key split keyboard. It is based on the Half-Swept, but uses RP2040-Zero microcontrollers (which are smaller, generally cheaper, and can be easier to work with). What's included 2x PCBs …
Read More…This is a 34-key split keyboard. It is based on the Half-Swept, but uses RP2040-Zero microcontrollers (which are smaller, generally cheaper, and can be easier to work with).
To assemble and operate, you will need:
2x Waveshare RP2040-Zero modules
34x Kailh Choc Key Switches + 34x compatible key caps
2x PJ-320D 3.5mm stereo jacks
1x 3.5mm TRRS cable
1x USB-C cable
There are a few other modifications to the original Half-Swept:
There is no switch
The jacks are slightly higher up the board, and they use a SMD (PJ-320D) footprint rather than the through-hole PJ-320A (I actually used PJ-320As and bent the pins for my build).
Enter your email address if you'd like to be notified when RP2040-Zero Half-Swept Split Keyboard (PCB) can be shipped to you:
$14.99
$49.99
