The first 4 modes USB zigbee adapter: *1* USB Stick *2* Ser2net (Wifi) Hub *3* LAN Hub *4* Raspberry PI Zero Hat
Designed by Gio-dot in ItalyNo shipping info available.
Z-Bee Duo Is an innovative zigbee adapter (coordinator or router) in form of usb dongle. It can be used with popular zigbee integrations like Zigbee2mqtt, Homeassistant ZHA etc. It is designed with t…
Read More…Z-Bee Duo
Is an innovative zigbee adapter (coordinator or router) in form of usb dongle. It can be used with popular zigbee integrations like Zigbee2mqtt, Homeassistant ZHA etc. It is designed with the new generation CC2652 Texas Instruments chip, in the most powerful version -P (+20dB embedded RF amplifier) and represents an upgrade of previous CC2530/CC2538/CC2538+CC2592 in terms of processor, ram and support.
Z-Bee duo is the easiest multimode zigbee coordinator/hub. No difficult configurations needed for wifi or ethernet side!!
The unique design of the Z-Bee Duo allows to use it in 4 different ways:
Standard USB coordinator (connected to a host where home automation software like Home assistant is installed).
Wifi connected (ser2net) coordinator: with the optional wifi module (that fit inside Z-bee case), Z-Bee Duo can be wirelessly connected to your home automation hub. In this way it can be moved away from your hub (simply powered by a cellular charger) to find the best position in the house and/or to avoid usb 3.0 Raspberry pi4 issues that in many cases affect USB connected adapters.
LAN connected coordinator: with the optional Ethernet module (that fit inside Z-bee case), Z-Bee Duo can be connected to your home automation hub through an ethernet port. In this way it can be moved away from your hub (simply powered by a cellular charger) to find the best position in the house and/or to avoid usb 3.0 Raspberry pi4 issues that in many cases affect USB connected adapters.
Independent zigbee2mqtt hub: a Raspberry PI Zero W (not included) can be coupled with Z-Bee Duo (it fits in its case); with zigbee2mqtt installed on PI Zero, the most compact and powerful standalone zigbee coordinator hub can be realized. It communicate in mqtt with home automation hub (Home assistant and others). This hub can be moved away from your hub (simply powered by a cellular charger) to find the best position in the house and/or to avoid usb 3.0 Raspberry pi4 issues that in many cases affect USB connected adapters.
NOTE: optional Wifi or Ethernet modules can be added in any moment to an existing Z-Bee usb. Please send me a message if you need one.
Technical features
What is included?
Options
Enter your email address if you'd like to be notified when Z-Bee Duo. Modular CC2652P zigbee 3.0 adapter can be shipped to you:
Documentation: (4.75)
Shipping: (4.88)
Communication: (4.62)
Roberto | May 25, 2022
Andreas | Feb. 22, 2022
Johannes | Sept. 17, 2021
Christian | Sept. 12, 2021
Csaba | Aug. 20, 2021
Alessandro | July 28, 2021
Morten | July 2, 2021
Stephen | June 17, 2021
$80.00
$55.99
