IMPORTANT: THE FLIPPER ZERO IT'S NOT INCLUDED ON THE PURCHASE, IT'S ONLY FOR DEMONSTRATION TO SEE HOW THE BOARD STAYS ON. Introducing Root Access Our New All-in- One Board 📬 Get in Touch If you have…
Read More…IMPORTANT: THE FLIPPER ZERO IT'S NOT INCLUDED ON THE PURCHASE, IT'S ONLY FOR DEMONSTRATION TO SEE HOW THE BOARD STAYS ON.
📬 Get in Touch
If you have any questions, please don't hesitate to reach out to me. Feel free to send a message anytime. Sometimes I might take a little while to respond, but I always do! 😊
Board Specs:
6 - IR LEDs 940 nm are high-performance
1 - E07-900MM10S runs in the 868 MHz to 915 MHz spectrum
1 - E07-400MM10S runs 410 MHz to 433 MHz band
1 - ESP32 - flashed with Marauder software
3 - Antennas
All our boards are meticulously tested before shipping to make sure You get fully operational product! Upgrade your Flipper Zero today with our feature-packed expansion board – where innovation meets precision. Unleash the power of connectivity and explore the limitless potential of your Flipper Zero!
What exactly is it?
It gives us great pleasure to present our newest design: a sleek, high-performance Board combining the greatest aspects of our most often used boards into one.
The E07-900MM10S runs in the 868 MHz to 915 MHz spectrum. Operating in the 410 MHz to 433 MHz band, the energy-efficient and robust E07-400MM10S offers ultra-long-range communication with outstanding signal stability over great distances, even around barriers. Both modules let you modify frequency within their ranges, thereby allowing you the freedom to fit them to your particular requirements—that of mid-range dependability or great long-distance coverage.
Perfect for wireless exploration and research, the ESP32-S3 has Wi-Fi, Bluetooth, and superior computing power.The Marauder firmware pre-installed comes with this module, it unlocks its full capabilities and allows functions such packet sniffing, signal scanning, and deep wireless analysis. This dynamic team is quite flexible and performs brilliantly. Enter the realm of wireless hacking and release countless opportunities.
Invisible to the Naked eye, the 6 IR LEDs 940 nm are high-performance infrared diodes running at a wavelength of 940 nanometres. These LEDs release improved infrared capability when coupled with the Flipper Zero. Use them to send and replicate IR signals, thereby allowing you to directly operate appliances such TVs, cameras, or other IR-enabled items from your Flipper Zero. Although humans cannot see the 940nm wavelength, its output may be found using smartphone cameras or specialist sensors, therefore guaranteeing exact signal testing and debugging. Their quiet and deliberate lighting also makes them perfect for low-light low-key activities or tests. Explore, analyse, and duplicate infrared protocols with the Flipper Zero and IR LEDs 940 nm, therefore transforming your device into a flexible tool for hacking, automation, and experimentation. Own the invisible spectrum right now!
Why did you create it?
This board's basic concept was to help you to simplify your life. Many persons were mixing many boards to get their desired effects, which usually resulted in crowded installations and compatibility problems. We so opted to design everything into one small, effective board thereby removing the necessity for several components. This board is meant to satisfy your requirements. It's adaptable, strong, and meant to save you time and effort while producing amazing results.
What distinguishes it from others?
This board was created using hacker mind set rather than simply construction. More than a tool, it's a canvas for your most audacious ideas, meant to promote creativity, exploration, and invention.
Not only the technology but also the flexibility it affords makes it quite unique. This board fits your vision without restrictions whether your goals are pushing limits, solving issues, or exploring the unknown.
It's about your possibilities with the board, not about what it does. Designed to inspire, designed to perform, and created for those who reject to live with average.
Create smarter hacks. Create with fearless fear. Open limitless opportunities.
Should You Buy It?
This board contains everything you need whether your focus is on testing RF signals, IR signals,looking at network vulnerabilities. It's about opening countless opportunities rather than only utility. Perfect performance, simplicity of use, and versatility make this board your best friend for wireless research.
Because occasionally, one board truly is all.
🌟 A Grateful Heartfelt Thank You
We sincerely thank you to everyone who has bought our boards and believed in us to help us on this road. Your confidence and energy inspire us to keep developing tools that enable your initiatives and creative ability.
We couldn't have the community we know without you, thank you for being part of it. One idea at time, let us challenge limits together and shape the future! 🌟
Thank you,
DTech✌️
Enter your email address if you'd like to be notified when Flipper Zero ROOT ACCESS can be shipped to you:
Hello
For all our customers in the United States, we want to inform you that, unfortunately, shipments from Europe to the United States are currently suspended.
We await the normalization of this situation as quickly as possible.
We appreciate your understanding.
DTECH
Hello :) Additional information regarding shipping prices, contact me. There is no exact table, as the values change depending on the country or carrier. Therefore, if you have any doubts and want a more real value, please do not hesitate to ask.
VAT Fees and taxes are paid by the buyer, taking into account the country of destination and its regulations.
Documentation: (4.67)
Mark | Dec. 12, 2025
Paolo | Aug. 19, 2025
Silvan | Aug. 10, 2025
$100.00
$100.00
$70.00
$80.00
$80.00
$23.99
$19.25
