A small and flexible button that can be easily integrated into your projects. Easily connectable button for various MCU platforms.
Designed by D&N-Tech in Slovakia
Adjustable Touch Button Adjustable Touch Button is a compact and versatile touch-sensitive button designed for easy integration and connectivity. Whether you need multiple touch inputs or a seamless…
Read More…
Adjustable Touch Button is a compact and versatile touch-sensitive button designed for easy integration and connectivity. Whether you need multiple touch inputs or a seamless mounting solution, this button simplifies the process. The idea originated from a real-world challenge—when implementing 12 touch buttons into a device, I realized that traditional options require separate wiring for each button, resulting in complex and bulky connections. This project aims to solve that problem by offering a more efficient and streamlined design
Command: 0xC1
Data: R (0-255), G (0-255), B (0-255), Intensity (0-100)
Receive String: "OK\r", "UNK\r", "ERR\r", "OVF\r", "WAI\r"
SET NOTOUCH COLOR
Command: 0xC2
Sensitivity
Command: 0xC3
Data: Sensitivity Level (1-4)
Change I2C Address
Command: 0xC4
Data: I2C Address (1-127)
Enable Interrupt Pin
Command: 0xC5
Data: 1 – Disable, 2 – Enable
BTN Status
Command: 0xC6
Data: (not sent)
Receive Value: 0xAA – Button Pressed,0xBB – No Press
Receive String: "UNK\r", "ERR\r", "OVF\r", "WAI\r"
Enter your email address if you'd like to be notified when Touch Sensor can be shipped to you:
| Quantity | Price |
| 1 | $11.40 |
| 2-4 | $9.50 |
| 5-9 | $9.00 |
| 10+ | $8.00 |
$64.99
$156.00
$129.00
