Compact SGP41 gas sensor module with SHT40 temp/humidity compensation, 3.3–5V supply, Qwiic connector for easy plug-and-play air quality sen
Designed by SIYUAN in China
What is it? This is a compact SGP41 gas sensor breakout board with integrated SHT40 temperature and humidity sensor for real-time compensation. It detects VOC (volatile organic compounds) and NOx (ni…
Read More…What is it?
This is a compact SGP41 gas sensor breakout board with integrated SHT40 temperature and humidity sensor for real-time compensation. It detects VOC (volatile organic compounds) and NOx (nitrogen oxides) to provide reliable indoor air quality data. Designed with a Qwiic connector and wide 3.3–5 V supply range, it works seamlessly with Arduino, ESP32, Raspberry Pi, and other I²C-capable platforms.
Why did you make it?
I wanted an easy-to-use SGP41 module that beginners and makers can quickly integrate into projects without soldering or level-shifting issues. The onboard SHT40 ensures accurate measurements by compensating for environmental temperature and humidity changes.
What makes it special?
Compared to typical gas sensor breakouts, this board combines VOC/NOx sensing and precision humidity/temperature feedback in a single Qwiic-ready design. Its 3.3–5 V compatibility, small footprint, and pre-routed I²C interface make it ideal for air quality monitors, smart home devices, or scientific experiments with minimal wiring and maximum reliability.
Enter your email address if you'd like to be notified when SGP41 gas sensor module can be shipped to you:
$24.52
$44.99
