Difference Amp Board: classic differential amplifier with adjustable gain stage. Board only.
Designed by Coded Devices in Finland
What is it? The Coded Devices Difference Amp Board implements a classic differential amplifier circuit followed by an adjustable gain stage. This product is board only; components are not included. A…
Read More…What is it?
This product is board only; components are not included. An example parts list is available on our website (www.codeddevs.com ) to help you get started.
Why did you make it?
This board was originally designed for my own project to measure the voltage drop across a shunt resistor using a low-noise, compact differential amplifier. After using it successfully, I decided to offer it to others who might need a similar solution.
What makes it special?
The board uses a four-layer PCB with clear signal routing on the top layer for improved signal integrity and easier inspection. The board runs on a single supply voltage.
In addition to the differential input stage, a variable gain stage allows the output range to be matched to the following circuitry. Optional low-pass filtering and protective diodes are included for flexibility and robustness.
Enter your email address if you'd like to be notified when Difference Amp Board can be shipped to you:
Orders are typically dispatched within 10 days. Customs duties and taxes are not included in the shipping rate. If you have any questions, please contact us before ordering. Thank you.
