The HC1008 is a super compact I²C Humidity and Temperature sensor with a resulution of 14Bit. It measures from 0%-100% and -20°C to 85°C
Sold By Der-QuerDenker
$34.99
$24.99
$562.00
HDC1008 Breakout board This is a super small breakout board for the HDC1008 humidity and temperature sensor from Texas Instruments. It is just 9x13mm in size and can be used with a standard 2.54mm/0.…
Read More…This is a super small breakout board for the HDC1008 humidity and temperature sensor from Texas Instruments. It is just 9x13mm in size and can be used with a standard 2.54mm/0.1inch pin header to place it right on your existing PCB or bread board, without the complications that come with soldering a tiny BGA chip.
The HDC1008 is a digital humidity sensor with an integrated temperature sensor that provides excellent measurement accuracy at very low power. The humidity and temperature sensors are both factory calibrated to insure best Quality. The sensor itself is placed on the bottom side of the small BGA chip so that dirt and other contaminations have a hard time to reach the sensor itself.
I designed that board because I needed a measuring grid for my rainforest terrarium. I tried another chip but I needed level shifters to shift the signal from 5V to 3V. They also had just a single address with meant that I had to use a bus switch too. I found the HDC1008 and that solved all my problems at onece! no level shifting and four sensors on diffrent places in the terrarium which are capable to handle the high humidity of a rainforest.
If you buy one I would be really happy to read what you did with it!
I wrote an Arduino library for it: https://github.com/RFgermany/HDC100X_Arduino_Library
But I found later a better one written by Francesco Truzzi: https://github.com/ftruzzi/HDC1000-Arduino
| Quantity | Price |
| 1-4 | $8.00 |
| 5+ | $7.30 |
Kai | June 15, 2015
$17.00
