Manipulate your home devices with alexa, google home etc or even a phone app
Designed by DeadSec-IoT in PortugalThis product is no longer available for sale.
What is it? This PCB allows you to connect your devices like lights, gate, blinds, etc. to the internet and allow you to change their status (ON, OFF) using smart home devices like Alexa from amazon,…
Read More…This PCB allows you to connect your devices like lights, gate, blinds, etc. to the internet and allow you to change their status (ON, OFF) using smart home devices like Alexa from amazon, google home, and many more.
I developed this IoT PCB to automate my home in a simple way using the ESP8266 and relays. This PCB is equipped with all the needed features to make automation easy.
This ESP8266 doesn't come with any pre-flashed code, but if you have any or would like me to develop the code to work in your home, just let me know when you order. To use this board, I highly recommend using the Sinric pro service or Esphome with Home assistant since it's easy to start and works well with all smart home devices (Alexa, Google home), plus it has a mobile app.
To flask any code to the ESP, you will need some jumper wires and a USB-to-Serial converter.
For extra information, please refer to Beginner guide to ESP8266
Min Input voltage -> 7V
Recommended Input voltage - > 12V
Max Input voltage -> 18V
Note: You can also power the device with 5V using the 5V pin.
HeatSink and fan are recommended for voltage regulators.
1-9 | $9.00 |
10-19 | $5.00 |
20+ | $4.00 |
$43.00
$13.80
$7.95
$3.95
